Get EEP's Premium Membership.
Home / Download Center / Electrical Software / Underground Cable Ampacity
Calculator
You may find the allowable ampacity for underground cable configurations by taking the time to look up the tables and diagrams of the Canadian Electrical Code. Using this underground cable ampacity calculator you will be done in a minute.
It will save you hours in a year, and most importantly it will reduce the chance of making an error.
Productive
Determine required feeder gauge for given configuration very fast. Quickly apply required correction factors. Paste the selected feeder configuration diagram to any application.
Flexible
Select feeder parameters in any sequence you like. Has built in wire cross-section data and minimum duct size information.
Easy to use
Does not require manual. Just select options and values.
Software:Underground Cable Ampacity
Version:
Developer:MC Group
Price:Shareware, 30USD
Short Circuit Calculator
  1. wareagle
    Oct 18, 2012
    I am in need of a program to assist in transmission line caclulations. It needs to provide sag, wind loading, ice loading pole class, tension etc. Hopefully freeware. Can you assist.
    Wareagle
