Home / Download Center / Electrical Software / Calculation of Touch Voltage and Ground Current
3-phase systems and 1-phase
Calculation of touch voltage and ground current can be performed on single phase or three-phase systems.
According to the inputs for three-phase system: Line-to-Neutral Volts (Vn), Line 1 Calculated Load (A1), Line 2 Calculated Load (A2), Line 3 Calculated Load (A3), Service Neutral Impedance Z1, and Ground Resistance (3-point method) R, spreadsheet will calculate the following parameters:
  1. Resistance of Each Phase
  2. Resistance of neutral/Ground
  3. Neutral Current and Load
  4. Touch Voltage for Metal part to Earth
  5. Body Resistance and Body Current
For single-phase systems input parameters are: Circuit voltage and ampere, load, ground, electrode and body resistance.
Software: Calculation of Touch Voltage and Ground Current
Version: 22.08.2012 New
Developer: Jignesh Parmar
Price: Free
Touch Voltage and Ground Current Calculation
7 Comments
  1. Er DEBASISH PATTANAIK
    Dec 26, 2014
    Dear Friends,
    Recently we have installed a 500kwp solar power plant in our state .It is a on grid system,about 25 nos of solar inverters have been installed in a area of around 1.5 km radius in different building.Here we found that the 20 kwp inverters at last building is developing over and under voltage and going failure.So pls anybody suggest what could be the reason for this and available solution.Thanks
    • Harnam Trehin
      Jun 09, 2015
      Please send me your single line and distances of each inverter from each other and from the load centre. Also please tell me what is the switching frequency of your IGBTs. Log onto our website we can help you if you still have the problem with the last inverter.
      Thanks,
  2. saeid
    Feb 22, 2014
    in the name of god
    tnx a lot
    helpful
  3. farajzadeh
    Sep 07, 2013
    I am an electrical engineer and I’d like to express my great thanks to managers of this web site and its all writers. Meanwhile, I want to add one general comment. Normally in spreed sheets, the american units (mile, foot square, AWG and…) are being used. Please develop equivalent METRIC sheets too.
    Regards:
    Farajzadeh
