Size of Diesel GenSet
This spreadsheet intend to calculate size of needed diesel generator according to the following input parameters:
- System Voltage ( P-P ) in Volts
- System Voltage ( P-N ) in Volts
- Future Load Expansion in %
- Average Intermittent Use of Equipment (0.7 To 1.0)
You are about to enter following information for each consumer you have in your consumption calculation:
- Equipment (name)
- Load Type (linear, non-linear or motor)
- Supply (1ph or 3ph)
- Qty (num.)
- Load (in kW)
- Starting P.F
- Running P.F
- Diversity Factor
- Motor Starter (Dol, Y-D, auto-transformer, soft starter or frequency converter)
Calculated results consist of:
- Size of Diesel GenSet for linear, Non-linear Load
- Size of Diesel GenSet for motor load
- Diesel GenSet Efficiency
- UPL (unit per liter) of Diesel GenSet
- Unit power cost of Diesel GenSet
- Approximate fuel consumption
Software: | Calculate Size of Diesel Generator (MS Excel Spreadsheet) |
Version: | 22.08.2012 ![]() |
Developer: | Jignesh Parmar |
Size: | 138 Kb |
Price: | Free |
Download: | Right here | Get Download Updates | Get Technical articles |
John Alias
can anyone please send the detailed calculations and formulas used in this spreadsheet?…it would be really helpful
SHANTANU DESHPANDE
What is the difference between Average Intermittent Use and Diversity Factor ??
Faihan
Good Job
How do I add the Air Conditioning units? Are they linear or non? I only know the ton value of each.
And, What is the correct connection for single phase ACs and lights? Is it Y-D?
I also have a three phase 60 HP submersible pump that sucks 150 Amps on each phase to start and then goes to 90 Amps to run. Your sheet says that the full load Amps is 38 while I see on the DG display 90 Amps on each of the three phases.
abel
What about considering non linear loads in %age of total load in sizing? The limits of such loads govern sizing if exceeded. Any international standards talks about this in sizing the Genset? How it will be applied in the calculation?
NEIL MAJUMDER
Consider a case where EDG is to be started on to a distribution transformer.How to size the DG set then?
sriram
we have total load in kw .how do we arrive at genset capacity??/
devadath.g
How can we conduct the load test of DG set at site?
Ahmed
Engine overload is 10% only not 130 to 150%.
It is depend for Standby application or Prime or base load .
It is better to check and alternator efficiency is about 93 to 96
eleng2007
how to calculate the required daily / monthly fuel tank of generator?
Edvard
Hooh, sounds very interesting, but I wouldn’t know really. I guess that eash manufacturer has its own manual or guide you should follow.
Anyway, your question’s answer depends on how many hours generator will work.
Adrian
Edvard, Can I get a password to unprotect the spreadsheet?
srikanth.shanky
Wonder that the starting power factor of the motor assumed to be as 0.8 is correct.Normally the value may be 0.2-0.3.The pf at 80% of speed during starting may be 0.6.Moreover the highest rated motor starting with base load and as well as voltage drop need to be considered for DG sizing.
Your feedback please.
partoshal
I’m not able to download this item. Please guide me.
Thanks a lot
Edvard
Link works quite well, I double checked. Maybe you’re having problems with Box.com on your side?
Mahesh
I’m not able to download this. I also tried to download other sheets some time back but faced the same problem.
Please suggest.
JaymzSchmerzen
Real useful.. Double checked my calcs =)
Thanks a lot
Jerome
Sir,
How accurate the spreed sheet is? this have been tested on site?
Thanks!
