Home / Download Center / Electrical Software / Lightning Protection Risk Assessment Calculator
Lightning Protection Risk Assessment Calculator (photo: An epic storm over city of Kosice (Slovakia) with lightning bolts blasts too close for comfort by Martin Lajs via Flickr)
Lightning Risk Assessment Study
Lightning Risk assessment Study is actually the measure of risk of a lightning strike and probability of damages. It assesses the lightening risks to the facility according to international standards requirements.
These calculations are according to IEC Standard 62305-2.
All these calculations are based on:
  • lightning strike density in that particular area (provided by OMV i.e. Ng = 8),
  • Danger for people,
  • Occupation coefficient of structure,
  • Relative location of site,
  • Fire Risk,
  • Associated services,
  • Electrical Lines,
  • Lightning Protection Level,
  • Surge Arrestor and
  • Dimensions of installation.
Brief introduction of all are given below.
Lighting Strike Density (Ng)
It is the measure of lightning strikes per kilometre square per year in the particular area.
Higher the lighting strike density, higher the probability of lightning strike which needs higher level of lightning protection level.
Danger for People (h)
It is the factor of presence of people and panic in the building in case of a lightning strike.
No particular danger1
Low panic level(<=2 floors, < 100 persons2
Medium risk of panic (< 1000 persons)5
Difficult to evacuate (disabled people, hospitals)5
High risk of panic (> 1000 persons)10
Hazard for surroundings or environment20
Contamination of surroundings or environment50
Occupancy Coefficient (Lf1)
It is the risk reduction factor with respect to theoccupancy of the building / installation. For example, loss due to lighting strike is higher in hospital as compared to a store / warehouse.
Structure unoccupied0.1
Structure normally occupied0.01
Relative Location of Site (Cd)
It is the risk reduction factor with respect to the location and surrounding of the building / installation. For example, chance of lighting strike is minimized if the building is near to a high tower.
Structure surrounded by higher objects or trees0.25
Structure surrounded by similar or lower objects0.5
Isolated structure-No other objects nearby1
Isolated structure on top of a hill or a hillock2
Fire Risk (rf)
It is the risk reduction factor with respect to the flammability of the material present in the building / installation. For example, in case of lighting strike, loss will be very high at a gas station as compare to the cement store.
Explosion1
High0.1
Ordinary0.01
Low0.001
Continue reading in Manual (available for download below)
Software:Lightning Protection Risk Assessment Calculator
Version:
Developer:Shafqat Ali
Price:Free
Manual:Right here | Get Download Updates | Get Technical articles
Lightning Protection Risk Assessment Calculator/Spreadsheet
11 Comments
  1. Terens Katzao
    May 13, 2016
    Wow! I like the software, I compared its results with a risk assessment that I did manually and the two results are almost similar.
  2. Ermin Delgado
    Dec 16, 2015
    Hello
    I can´t donwload the arhive.
    The archive no dowload.
  3. George
    Sep 13, 2015
    Hi, can I get the LPL / Class after I do this risk assessment? I have a task to determine LPL of a structure and still cannot find calc that will give me an answer to it.
    Your reply will be appreciated!
  4. kslim
    Mar 06, 2015
    I have a question.
    How can i see the calculation result? I can not see the result after enter some information..
    Excel sheet only one and It’s locked even..
    Please give me a instruction. Thanks.
  5. kslim
    Mar 05, 2015
    I have a question.
  6. ABDULRAHMAN HASSAN MOHAMED
    Mar 04, 2015
    Dear manger,
    i have roof top with 13 meters width and 19 meters length and the high of the building is
    45 meters,
    will you please give the total copper that imus use thank you
  7. Mark
    Mar 03, 2015
    Its a great software, thanks!!
    There is a question about Occupation coefficient of structure that I don’t really understand what it means.And I couldn’t find any similar parameter in 62305-2.
    Could you please help me explain this item? Thanks a lot!!
  8. Rajan Varma
    May 31, 2014
    really it will be great to calculate the lighning stike for high rise building. thanks
  9. Gianni Burioli
    Feb 06, 2014
    Hi
    Great software and very useful
    Can I have the mail address of the author of this software?
    I would suggest some improvements
    (I’m a engineer)
  10. st01
    Sep 26, 2013
    big thanks
