Home / Download Center / Electrical Software / Calculate size of battery bank and inverter
This MS Excel spreadsheet calculates the following parameters:
  • Total Demand Load
  • Size of Battery Bank in Amp.Hr.
  • Select Type of Connection of Batteries in Battery Bank
  • Select Rating of Each Battery in Battery Bank
  • Size of Inverter
  • Size/Type/Tripping setting of Main MCCB.
Software: Calculate size of battery bank and inverter
Version: 22.8.2012 New
Developer: Jignesh Parmar
Price: Free
10 Comments
  1. Edward Gilmour
    Mar 26, 2016
    In calculating anything in relation to secondary battery charging one has to consider the maximum charge current of each cell or battery!There is more to consider than what is in that spread sheet.
  2. mne amin
    Apr 14, 2015
    hi
    thanks for your technical helps.
    h would be pleasure if you explain more about:
    battery type (acid/nickel cadmium)
    an easy example calculation
    kw unit for inverter size seems not ok
    thanks again
    mne Amin
  3. vikram
    Mar 21, 2014
    Could u please give the method for calculation?
  4. MILAD3118
    Sep 29, 2013
    HI AND THANKS FOR THIS
    I HAVE PROBLEM …. I CAN T DOWNLOAD THIS FILE AND OTHER FILES … I M VERY UNHAPPY FOR THIS PROBLEM PLEASE HELP ME .ARAL.MILAD@G,AIL.COM
    THANKS AND BEST REGARD
  5. ashu.tiwari
    Jul 23, 2013
    Thanks for such a good tool….
    If there can be an article explaining each and every step that would have been wonderful.
  6. Muhammad Arslan
    Jul 06, 2013
    what is password for this software. it is password protected.
  7. nick.karanikos@yahoo.gr
    Jan 10, 2013
    Please correct the units in the “Size of Invertor” box from KW to Watts, in the “Battery size Calculator(28-5-11).xls”
      Edvard
      Jan 10, 2013
      Thanks for noticing, I’ll inform mr. Jignesh about your sugesstion.
