Home / Download Center / Electrical Software / Calculate Bus Bar Size and Voltage Drop
Busbar voltage drop calculation
  • Calculate Voltage Drop for  Bus Bar
  • Select Size of Bus Bar for particular Load
  • Enter Your Sub Panel Details like Load,Line Length
Software:Calculate Bus Bar Size and Voltage Drop
Version:22.8.2012 New
Developer:Jignesh Parmar
Price:Free
29 Comments
  1. juan bautista
    Jul 09, 2016
    Do I have to subscribe to every download or technical article I need?
  2. Krishna Ankam
    Dec 29, 2015
    To unprotect the excel sheet
    Alt+F11
    view (Alt+v)
    code (F7)
    paste the following in the white space
    Sub PasswordBreaker()
    ‘Breaks worksheet password protection.
    Dim i As Integer, j As Integer, k As Integer
    Dim l As Integer, m As Integer, n As Integer
    Dim i1 As Integer, i2 As Integer, i3 As Integer
    Dim i4 As Integer, i5 As Integer, i6 As Integer
    On Error Resume Next
    For i = 65 To 66: For j = 65 To 66: For k = 65 To 66
    For l = 65 To 66: For m = 65 To 66: For i1 = 65 To 66
    For i2 = 65 To 66: For i3 = 65 To 66: For i4 = 65 To 66
    For i5 = 65 To 66: For i6 = 65 To 66: For n = 32 To 126
    ActiveSheet.Unprotect Chr(i) & Chr(j) & Chr(k) & _
    Chr(l) & Chr(m) & Chr(i1) & Chr(i2) & Chr(i3) & _
    Chr(i4) & Chr(i5) & Chr(i6) & Chr(n)
    If ActiveSheet.ProtectContents = False Then
    MsgBox “One usable password is ” & Chr(i) & Chr(j) & _
    Chr(k) & Chr(l) & Chr(m) & Chr(i1) & Chr(i2) & _
    Chr(i3) & Chr(i4) & Chr(i5) & Chr(i6) & Chr(n)
    Exit Sub
    End If
    Next: Next: Next: Next: Next: Next
    End Sub
    then press “F5”
    and wait for sometime
    thank you
    Krishna
  3. DJINTHE
    Jul 28, 2015
    Bonjour Monsieur,
    je n’arrive pas à télécharger les fichiers excel. pouvez vous m’aider? svp
  4. sudhakar
    Jul 24, 2015
    Hi.
    Can u pl explain hot to calculate current rating of bus bar. and pls share the formula.
  5. Zeeshan
    Feb 12, 2015
    Please provide an example… unable to understand that how to use..??
  6. mahmoud fawaz
    Nov 30, 2014
    Hi. How to calculate the drop voltage for 25mm2 cable three phaze +earth . 350m 4 A
  7. RJ Ordonez
    Sep 30, 2014
    there’s no unit for power on the spread sheet. is it in kva or kw? thanks!
  8. Lele
    Aug 18, 2014
    Dear EEP
    Lele
  9. Sagar Jadhav
    Jul 27, 2014
    bus bar formula
    • ajit bhatavkar
      Aug 08, 2014
      Pls give me my email id bus bar formula
      Regad
      Ajit
  10. Sagar Jadhav
    Jul 27, 2014
    Dear sir,
    I ask you what is the bus bar calculation formula?
  11. sohel
    Jun 26, 2014
    In case of Busbar voltage drop calculation you take Resistance=0.005 ohm and reactance=0.011 ohm . what is the reference of these values. have any international code ? also how can i get a cable resistance and reactance ?
  12. Marvin
    Feb 15, 2014
    Very useful..Thank you very much..
  13. kakamta
    Nov 01, 2013
    thanks.but i don’t understand the way to calculation. please help?
  14. m.taqi
    Oct 25, 2013
  15. Ronald Acuavera
    Oct 09, 2013
    please advise and calculate, i have 5x1250Amps,.8pf, 220v gensets, synch to a common busbar, and two outgoing CB’s of 2500A, what will be the main busbar rating.
  16. NAGARAJ123
    Jun 19, 2013
    IN BUSBAR TRUNKING SYSTEM HOW DO YOU CALCULATE THE KA RATING OF THE BUSBAR. FOR EXAMPLE IF CUSTOMER ASKS US TO GIVE 50KA WITH 50x10mm ALLUMINIUM OR COPPER BUSBAR WHAT IS THE FORMULA WE HAVE TO APPLY PLEASE SOME ONE WHO KNOWS ABOUT HIS GUIDE ME
      Edvard
      Jun 19, 2013
      Customer normally shouldn’t ask you this, but to tell you the ratings of loads, so you can calculate the CBs in incomers and outgoing cubicles, as well as rating of main horizonal busbars. When you have all these information, you can calculate short curcuit withstand current on busbars.
  17. Eng. Bo.7sn
    May 27, 2013
    I entered the results but I didn’t know what is sin(phi) so i put it =0
    and the results below:
    Selected BusBar is Correct
    3.92 (Within Limit)
    What is the size of the bus bar ?
  18. yaqob
    Apr 24, 2013
    thank you for this great website
    but unfortunately I couldn’t download the excel calculation files! what should I do?
  19. sazali
    Mar 11, 2013
    thank a lot for all notes had published in this portal……
  20. pankajbhai Trivedi
    Jan 16, 2013
    Thanks for my registration.
    Pl. tell me How/D.G set automatically start when mains supply fails.
