Home / Download Center / Electrical MS Excel Spreadsheets (Calculations of cables, voltage drop etc.)
Electrical tools (MS Excel Spreadsheets)
This section is dedicated to tools every electrical engineer can use in daily work. These spreadsheets below will make your job much more easier, alowing you to shorten the time used for endless calculations of cables, voltage drop, various selections of circuit breakers, capacitors, cable size and so on.
Electrical Tools - MS Excel Spreadsheets
Spreadsheets are mostly developed by expirienced electrical engineers and programmers (thank you mr. Jignesh Parmar!) and by well known manufacturers of electrical equipment. They all really did an awesome job, you must admit!
Just to mention that all calculation spreadsheets are free for download! ;)
Electrical calculations (MS Excel Spreadsheets) New Download
Motor Starting Calculation Spreadsheet (by Hemant Kashikar) star .
Cable Designing Program Updated .
Calculate Home Electrical Load & Electrical Bill Updated .
Calculate Bus Bar Size and Voltage Drop Updated .
Calculate Electrical Load and Energy Consumption of Panel Updated .
Calculate Electrical Load of Panel Updated .
Calculate Insulation Resistance Value Updated .
Calculate Number of Lighting Fittings and Lumen Output Updated .
Calculate Size of Battery Bank and Inverter Updated .
Calculate Size of Solar Panel, Battery Bank and Inverter Updated .
Circuit Breaker Tripping Settings Updated .
Conduit Size Selection Program Updated .
Design of Earthing Mat for Sub-Station Updated .
Selection of MCCB, ELCB For Main-Branch Circuit Updated .
Selection of fuse and setting of instant short circuit tripping of CB Updated .
Short Circuit Current Calculation at Various Point of Electrical Circuits (Isc) Updated .
Size of Capacitor For Power Factor Improvements Updated .
Fault Current Calculation star .
Electrical Safety Program Arc Flash Calculator .
E-Feeder and Cable Calculator .
SquareD – Selecting capacitor size .
Voltage Drop Calculator – Albany Technical College .
Cable size calculations based on motor horse power (HP) and specified current .
Voltage Regulation Percentage of Small Distribution Line .
Calculate size of air conditioning for room .
Residential Load Calculations .
Pump Efficiency Calculation Tool .
Transformer Fault Current Calculation .
Powerline Voltage Drop Calculation star .
Electrical calculations (MS Excel Spreadsheets) Download
Power Factor Correction Calculation star .
Calculation of Touch Voltage and Ground Current star .
IDMT (Inverse Definite Minimum Time) Relay Calculation star .
Calculate Size of Diesel Generator star .
Electrical Pole’s Trasverse Load Calculation New star .
Electrical Engineering General Formulas New .
CO2 Savings Calculator New .
Available Fault Current Selective Coordination .
Power Factor Table Calculator New .
NEMA Motor Data Calculator star .
Estimated Voltage Drop Calculator star .
IEC Motor Data Calculator star .
Calculation of Size of Transformer, Fuse and Circuit Breaker star .
Calculate Size Of DOL and Star-Delta Starter Components New star .
Calculate size of transformer and voltage due to starting of large size motor New .
Power Quality Solution Selection Spreadsheet New .
Spreadsheet For Calculating Size Of Motor Pump star .
Spreadsheet For Calculation The Required Number Of fixtures And Illuminance Level star .
Lightning Protection Risk Assessment Calculator/Spreadsheet .
Load Listing, Calculations and Generator Sizing Spreadsheet .
Spreadsheet for Transformer Losses Calculation .
Motor Voltage Drop Calculator (Spreadsheet) star .
Spreadsheet to calculate the size of neutral earthing transformer star .
Spreadsheet to Calculate Short Circuit Capacity of Diesel Generator Synchronizing Panel New .
Power factor correction calculations for power system New star .
Distribution Transformer Calculations New star .
Calculation of electro magnetic field (EMF) around T&D overhead lines New star .
191 Comments
  1. joniel tangapa
    Mar 25, 2019
    excellent reference it helps a lot.
  2. Rajesh
    Mar 03, 2019
    what is direction of fault current on radial MV feeder (11kV) how earth fault or overcurent relay works.
    what are the reason for catching of fire during fault?
  3. Anil
    Jan 16, 2019
    I am not able to download the excel sheet
  4. Ali Ahmad
    Jan 01, 2019
    i am not able to download the excel sheets
  5. Bala
    Dec 24, 2018
    Hi team,
    if there is any shortcuts or easy methods in testing commissioning,and how can reduce the commissioning time for particular tests..
  6. NIKUNJ PARMAR
    Nov 19, 2018
    Thank you so much for such a great files. these are one of the best tool for electrical systems. keep it up
  7. subhash
    Oct 13, 2018
    Best and nice work
    keep it up
    but a small correction require in cable size calculation ( excel ) sheet in 3.5 X 50 sqmm where the result is wrong
    by subhash from totalsolution.website
  8. Adil Agha
    Oct 06, 2018
    Great effort to organize EE info at one place, future target should be to evolve projects group.
    regards
    Adil
    EE
  9. LE VUONG
    Oct 04, 2018
    Thank you a lot for sharing.
  10. Vincent
    Sep 25, 2018
    Firstly, I highly appreciate your contributions. Thank you so much!
    Secondly, I have checked all the Excel sheets, I saw that most of them were protected, so I could not see the formulas, which I want to recheck. Can you help me to unlock them??
    • khan
      Oct 05, 2018
      sir I want to unlock the spreed sheet as most of them were locked and I cant change it according to my use can u give me pas or how to unlock it
  11. Qaiser Iqbal
    Sep 12, 2018
    These excel worksheets are very useful for design engineers. Thank you for sharing free of cost on purpose knowledge for everyone.
  12. Emmanuel
    Aug 28, 2018
    Very nice of you sir.
  13. Nguyễn Hoàng
    Aug 01, 2018
    Thank for your support…
  14. Ahmad Wahid
    Jul 28, 2018
    thank you, very useful.
  15. samer
    Jun 24, 2018
    that’s very helpful… great
  16. samuel.ayalew
    Apr 27, 2018
    Thanks a lot this is a great help for professionals and trainers. A real quality work with lots of consideration for fellow professionals in the stream. you are setting a higher example. Once again Thank you very much.
  17. SUBRAMANIAN NAMBISAN
    Apr 20, 2018
    Dear EEP Team,
    you are doing a wonderful job by making available such calculations for every day use by practicing engineering professionals, cs nambisan
  18. Shaddai
    Mar 10, 2018
    Thank you so very much.
  19. Mounir
    Feb 17, 2018
    Thanks a lot.
  20. Prawin
    Feb 11, 2018
    Thanks a lot. Very Very Helpful
  21. Khaled Ellithy
    Jan 25, 2018
    Excellent
  22. Tawa Great
    Dec 19, 2017
    Hello team EEP
    As a junior power systems engineer, which coding language would advise me to learn among:
    PHP
    Front-End Web Development
    Website Design
    Android Development
    iOS Development
    Python
    C#
    WordPress
    • Emin
      Jan 14, 2018
      Do you know anything about those languages? They are all completely different. Front-End Web development is not even a language; it’s an area, just like distribution systems engineering.
      I suggest you research a little bit before asking a question like this.
  23. ISLAM LIKA
    Dec 16, 2017
    i want to buy a lap top for scada system
  24. ANKUR SENGUPTA
    Dec 14, 2017
    Hello sir,
    I want to know that, is there any calculation table for transformer firewall protection?
    THANKS
  25. choi85
    Dec 12, 2017
    Thanks, very much..
  26. Raphael Sangrador
    Nov 10, 2017
  27. jayaraj.k
    Nov 09, 2017
    Dear All,
    I need to give the justification for selected cable 2 Runs of 185 Sq.mm.
    this cable selected for transformer solid ground conductor.
    Transformer details.
    13.8kV/480V
    4687 KVA
    Z=5.75%
    Dyn1 vector group
    Whether this cable is sufficient or not. please clarify with calculation.
    Thanks in advance
    BR
    Jayaraj.k
  28. Pisit
    Oct 21, 2017
    Nice solution
  29. Atiq
    Oct 10, 2017
    anyone have Siemens software (Starter v 4.3 for Siemens Drive(VFD) G120).please upload anywhere and send me link.
    thanks.
    Atiq
  30. Reda Mostafa
    Aug 30, 2017
    Please I like to calculate the required number of earth rods for substation mat specially in the preimeter
    Thanks in advance
  31. Carlos Espinoza
    Aug 15, 2017
    Thanks to Mr. Michal Liszka for the Excel EMF calculation.Do you know if this spreadsheet gives the electrical gradient of the conductors? or with some minor modification of the macro?
  32. Michael
    Aug 14, 2017
    Thanks… Thumbs Up
  33. Mirwais
    Aug 05, 2017
    Thanks a lot, Very usefull
  34. Mohammad reza Amirahmadi
    Jul 17, 2017
    Hi. Thanks, very usefull
  35. Prosper Kalu
    Jul 12, 2017
    God is going to bless and keep all the people doing this great work to make this world a more comfortable place. God is also going to help us in Africa to also take part in this great improvements. kudos to you guys.
  36. asrizal basir
    Jun 21, 2017
    Hi senior,
    I am looking for software for mp920 yaskawa plc,and cable data for programing
    We have problem with my machine and we must solve that problem.
    Where i am to get the software and cable data to connect to my pc
    Tq all
  37. QVN
    Jun 17, 2017
    Thanks a lot. very useful
  38. nabi
    Jun 15, 2017
    I need Electrical AutoCAD or same software for design of electrical schema please send me link of
  39. TOLBA
    Jun 10, 2017
    thank you very much sir
  40. CASIMIRO
    May 31, 2017
    Thank you very much.. It helps a lot
    Do we also computation, for Transformer single phase dry type (consumption with out load).
    Some say is negligible but waste of energy.
  41. Mohammed AbuRayya
    May 10, 2017
    Thanks a lot.
  42. anand
    Apr 12, 2017
    Please provide EXCEL sheet for following CT calculations
    One minute Power Freq. 70 kV & 28 kV withstand voltage (rms),
    Lighting Impulse withstand Voltage
    System fault level Rated dynamic withstand 62.5 Current (KA rms)
  43. peter malus
    Apr 03, 2017
    thank you very much. such information is very useful to me as a young electrician.
  44. Mohmmad Thapet
    Mar 23, 2017
    Thank you you helpful best regard
  45. Zorica Popovic
    Mar 14, 2017
    The best site ever!! Thank You very much for Your effort!!!
  46. Tarqiullah
    Mar 01, 2017
    Thank you of your work in Electric Engineering.
  47. hoss
    Feb 27, 2017
    Hello.
    Thanks a lot for your large Heart to share this useful knowledges.
  48. ashenafi
    Feb 23, 2017
    THANK YOU!!!!
  49. Hassan
    Feb 04, 2017
    Thanks a lot
  50. kiran Kumar Avadhanula
    Feb 02, 2017
    I have a doubt that we have a metal chimney of 63.5 mtrs height does we have to install air terminals and horizontal terminals to connect to ground for lightning protection or we can simply connect the chimney base to earth grid.
  51. Sridhar
    Feb 01, 2017
    One of the best knowledge sharing website. Great job by Edvard and his supporting team.
  52. Thabiso Boase
    Jan 19, 2017
    the best site,
  53. Ashraf Zaher
    Nov 30, 2016
    Thank you very much
  54. E MARTINEZ
    Oct 17, 2016
    Good day, do you have a spreadsheet to estimate cooling/heating for control panels?
    Thanks.
  55. mohamed
    Sep 26, 2016
    Could you please send to me all sheets because register now not allowed
  56. saman
    Aug 17, 2016
    Thank YOU very much, All of calculation is so Perfect . . .
  57. Ismaeil
    Aug 01, 2016
  58. Vigneswaran
    Jun 24, 2016
    Dear Palmer,
    I downloaded some of your excel sheets, but its not opening as I am using MS office 2013, is that a problem or your excel sheets only work with previous version of office. kindly reply.
    Thank you ,
    Vigneswaran
  59. ABDUL QAYYUM
    May 12, 2016
    DEAR ALL
    THANK YOU SO MUCH FOR THIS GREAT WEBSITE AND THESE LINKS
    BEST REGARDS
    YOURS
    ABDUL QAYYUM
  60. Pal
    May 09, 2016
    Sincere thanks and my appreciation to this wonderful forum.
  61. mouaz mohamed
    Apr 28, 2016
    thanks allot , appreciation to this wonderful forum
  62. Aditya Vyas
    Apr 25, 2016
    Thank you so much for the organised sheets. it really is helpful.
  63. Asst. Prof. Dr. Emad Kamil
    Apr 20, 2016
    DEAR ALL
    BEST REGARDS
    YOURS
    EMAD
    • Pablito Ortega
      Sep 14, 2016
      Sir,
      I’am Mr. Lito Ortega, i’m here in New York working to Delco Electric Co. as Electrical Designer. Where are you working now sir Emad. Please reply to my email at litortega@gmail.com.
  64. Bojan Petreski
    Mar 26, 2016
    WOW…. I just love you… there, I said it :-)
    thanks!
  65. Ricardo
    Mar 17, 2016
    what is X´mer?
    • K P Kesavan Nair
      Feb 17, 2017
      X’mer is short for Transformer.
  66. anwer
    Mar 16, 2016
    thank u this is very helpful
  67. SERGIO sds
    Mar 10, 2016
  68. Nasser .M
    Mar 03, 2016
    Thank you very match this was really very useful in the engineering design job . ,
  69. hazir
    Jan 11, 2016
    It’s amazing thank you so much sir…
  70. G UPENDER
    Nov 10, 2015
    with regards to all of u members
  71. Ramzi
    Oct 24, 2015
    Thank you for his wonderful work, they have been useful to me. Is it possible to provide me the password to modify the excel file. Regards,
  72. Essraa
    Aug 30, 2015
    Dear Gents,
    I have a project which I need to size a Power Control Center & Transformer for motors load driven through Variable Frequency Drives.
    Could you advise how to size the feeders of the PCC for each motor+VFD knowing that each VFD has an overload capability 1.5 times rated current for 60secs.
    Thanks in advance.
  73. khaled
    Aug 15, 2015
    coool,,
    thanks a lot they have been useful to me
  74. Pankaj Desai
    Aug 13, 2015
    Thanking you Mr. Jignesh Parmar and others for sharing wonderful, useful and data sheet and spreadsheet.
  75. Vikas Khengre
    Jul 17, 2015
    I need ups sizing Calculator. please mail me if you could provide me.
    Your help regarding on this will be very much appreciated.
    Vikas
  76. Bryant
    Jul 14, 2015
    A quick reference website for wire size and circuit protection calculations:
    http://wiresizecalculator.net/
  77. Harish
    Jul 06, 2015
    Sir,
    This is very HELP FULL for us , I am very Thanks to You sir, I Learned many thing from this site, Thank you so much.
  78. @st175
    Jun 25, 2015
    Hi, can you please help me with writing the code for calculating switching losses in an IGBT with unity power factor.I m suppose to use time slicing technique and estimate losses or switch state at 1000 time instants.
    Can you help?
  79. MD.Mohitul Haque
    Jun 25, 2015
    This was very helpful,thanks.
  80. Rami
    Jun 23, 2015
    Is there a link to download all the spreadsheets, instead of one by one? Thanks
  81. nikhil
    Jun 19, 2015
    please send me the spreadsheets
  82. Ravikumar
    May 23, 2015
    Dear Team ,
    I am unable to download the cable designing program MS EXCEL Spreadsheet . When I am clicking the above link ,the file is not coming .
    Can you pls help me to download .
    With Regards,
    R.Ravikumar
  83. mohamed
    Apr 15, 2015
    thanks a lot for this support to my new challenge work :)
  84. pradeep
    Apr 12, 2015
    I want to CODES/RELEVANT STANDARDS IE, IEC,IEEE & CBIP MANUALS.
  85. sathishchowdary
    Mar 27, 2015
    Dear Sir, I want how to select relay for a electrical usages.
  86. Tesfay Gebre
    Mar 25, 2015
    I really appreciation for your sharing a knowledge us. But I have question how can I access the resource because the MS excel spread sheet is read only?
  87. saravanan
    Mar 25, 2015
    Dear sir , can you provide me a spreadsheet to calculate harmonic . thank you.
    • Farhad Kohestani
      Oct 11, 2018
      You can find one in ABB site. Just Google harmonic estimator ABB group.
  88. omar
    Mar 04, 2015
    Dears if there Excel spreadsheet to calculate reactors size kindly provide me
    thanking you
  89. Pravin Sawant
    Feb 13, 2015
    thanks for sharing … kindly provide the password or keep it open sourced if you really want to share you knowledge.. because it is difficult to get the the formulae behind the calculation.
  90. Sumit
    Feb 13, 2015
    Hi
    I would be very happy if you can work upon and include excel tools for railway electrification engineering and estimation including QS.
    Sumit
  91. Agustin Laez
    Jan 24, 2015
    Please check the Excel Spreadsheets, Calculate size of transformer and voltage due to starting of large size motor,the cell E33 not working, excuse me english, no is very good.
    I speak spanish
    Thank
  92. SM
    Jan 17, 2015
    It’s Cool!!!
  93. Kristoffe Russel Carlos
    Jan 09, 2015
    can you provide me spreadsheet to calculate the sag and span and tension for transmission line please…thank you so much!
  94. trevor chandass
    Dec 26, 2014
    can you please provide a calculator to size transformers where three single phase transformers are used to create a full three phase or open delta bank with the measured phase load current as the inputs?
  95. tommy
    Dec 21, 2014
    please sent for me password unprotect file excel if can
  96. Kazem
    Dec 10, 2014
    Hi
    Calculated filter harmonic and filter D teuned
  97. Md Mosharaf Hossan
    Dec 05, 2014
    How i wll be able download excell sheeet
  98. Dimitrios Chouliaras
    Dec 02, 2014
    hello guys, im interested in calculate proper diesel generators for industrial projects
  99. kazem
    Oct 09, 2014
    Hi, thanks for the very good Excel files to calculate file requests Series Inductors which are industrial drives
  100. mohd azharuddin
    Oct 02, 2014
    Dear Sir,
    i am working on calculating Rct of current transformer please help me how to calculate this
  101. VICTOR RAUTA
    Aug 26, 2014
    Hi guys,
    i like the discussions in this wonderful forum.
    I AM STILL A STUDENT AND I HOPE TO BENEFIT FROM YOU
  102. Nagendra
    Aug 18, 2014
    I need the methods to calculate and select the proper size of XLPE cable for high voltage system. Can anybody help me providing the spreadsheet to select the proper size of XLPE cable for High voltage like (11-33-66-132kV) system.
  103. Mubeen
    Aug 18, 2014
    Hi.. I m trying to download MSCEXCEL spreadsheets on my android phone but it struck on box page and nothing happens when I press download button .. I also have installed box app but not working…
  104. haradongan pasaribu
    Aug 16, 2014
    I am interested in electrical software/ CD file designing for MV/LV circuits. can you guide me on that?
  105. Shine
    Aug 14, 2014
    I want Program Calculation for ups sizing…and ups spread sheet…
  106. Mohammed Yousuf A
    Aug 14, 2014
    Great job Mr Parmar, very helpful information in the site. nice….
  107. SOLANKI RAJESH
    Aug 11, 2014
    I NEED MONTHLY,DAILY Grid Availability – Seet plz help me
  108. Lars
    Jul 30, 2014
    Very nice spreadsheets. Anyone got one for calculating generator incomer CT?
  109. HARISH
    Jul 29, 2014
    Thank you very much sir…..
    really really thanks
  110. surasitw
    Jul 15, 2014
    I want Program Calculation .
  111. jafari
    Jul 12, 2014
    you are the best
    thank you veryveryveryvery veryveryveryvery much
  112. rijvan
    Jul 12, 2014
    I ll recomend this site for all engineer who never stop learning..
    I m feel lucky to visit this site
  113. sina.ma
    Jul 03, 2014
    Thank you very very much .
  114. dehghani
    Jun 29, 2014
    Thanks a lot………..
  115. shayesteh
    Jun 29, 2014
    Thank you verryyyyyy mach
  116. vivek sharma
    Jun 18, 2014
    I want to add some excel tools which can be useful in numerical relay testing. such as Delta connection counting, unbalance (NPS, PPS, ZPS) counting, all type power & energy calculations etc.
      Edvard
      Jun 18, 2014
      Great Vivek! You can send your spreadsheets to office/AT/electrical-engineering-portal.com.
  117. John Lovel
    Jun 12, 2014
    Really g8t Efforts and Thanks alot.
  118. Do Duc Thai
    Jun 11, 2014
    Please give us the password to use these tools.
  119. sun
    Jun 08, 2014
    required 132 KV transmission losses calculations
  120. Jermaine
    Jun 07, 2014
    This is a wonderful and very helpful thing that you have done. Do you have plans to do a medium voltage motor calculation sheet?
  121. NOEL MENDOZA
    Jun 04, 2014
    Im very glad tha you post this helpful and very usefull computation
  122. sudhir
    Jun 03, 2014
    great content for electrical engineers, please remove the protection for the files, we want to utilize it
  123. thank from your information
    May 20, 2014
    good information
  124. ZISHAN
    May 17, 2014
    All the excel sheets are password protected. How to remove the password
  125. Harrison U. S
    May 04, 2014
    I really wanna appreciate your support and help to electrical engineers all over the globe, your really a great source of help cos much time have been saved with the help of your spreadsheets. I wanna say thanks and heaven blesses you guys real good.
  126. DESSIE MELESE
    Apr 07, 2014
    I am Electrical engineer in Ethiopia. My interest is to be the member of number one 1 Electrical engineer in the world.
  127. chris weche
    Apr 03, 2014
    YOU GUY(S) ARE GOD-SENT,YOU ARE A BLESSING TO THE UNIVERSE.MAY THE ALMIGHTY GOD GRAND U FAVOUR IN UR ENDEVOURS TOO.
  128. Ayo
    Mar 25, 2014
    You guys have really done a good job. Having these spreadsheet handy for a rough estimate saves time a lot.
  129. Prashant Baldawa
    Feb 05, 2014
    Thanks EEP. Your articles are worth reading. Simple yet an insite to a many technical facts which we deal with on conitnual basis.
    Do you have any article on the autosnchronization scheme and its advantages/disadvantages.
    Thanks in advance.
  130. aruel
    Jan 26, 2014
    Thanks EEP for your generosity! I got all the spreadsheets almost 45 for free. a very helpful docs.
    God bless!
  131. A.shiraj Ahamed
    Jan 10, 2014
    I can’t download this software. But this is very important and very useful for all technical persons
  132. umut
    Jan 08, 2014
    İ cant download it
      Edvard
      Jan 08, 2014
      Please elaborate… cannot help according to ‘I cant download it’ ;)
  133. Yadagiri.Y
    Jan 03, 2014
    Pls, share…..!
  134. Ronald
    Jan 03, 2014
    Dear Sir,
    how to down load this?? thanks
    R.I
  135. Ramnik
    Dec 15, 2013
    could not use the Home Electrical Bill / Energy Consumption / Load Calculator
    it requires password the cells are protected. Can you send me the password PLEASE!
      Edvard
      Dec 15, 2013
      You can use this spreadsheet without any problem, but if you want to edit formulas and unlock the cells, you will have to purchase this spreadsheet.
      • Ramnik
        Dec 15, 2013
        but sir i cannot edit the “total electrical load” cell…
        plz help
      • satish korgaonakar
        Jan 01, 2014
        Any spead sheet which we downloads from this website ask for password , You replied we need to purchase the same , so tell me wats the price n wats is the procedure to do the same
  136. B.MANJUNATH
    Dec 12, 2013
    Dear sir,
    Please help me sir i am not able to download the Excel sheet details like voltage drop calculation, elrctrical formulad etc.,
      Edvard
      Dec 12, 2013
      Everything is available for free download, I don’t see any problem ;)
  137. Romel Bacay
    Dec 11, 2013
    Its awesome. Thank you very much for the references ..Pls. dont be sate to share your knowledge. Go will bless you.
  138. S S A
    Dec 11, 2013
    Please include the checklist for installation of electrical items (DBs/ Panels / Transformers / DG/ ACB etc)
  139. Pankaj Rane
    Dec 05, 2013
    It’s really very helpful , thanks a ton!!!!
  140. Arulanandan S
    Dec 04, 2013
    not available for down loading
  141. pd1986
    Nov 29, 2013
    files are not downloading from mobile please help
  142. oynotna
    Oct 25, 2013
    Salute!
  143. keshrimohit38
    Oct 09, 2013
    Awesome… Hats off to all of them … :)
  144. shergill
    Oct 06, 2013
    what is the password sir
  145. mk_sanaye
    Sep 27, 2013
    the information and softwares are really usefull but download links in http://www.box.com doesn’t work correctly and server doesn’t respond, please correct them
    thanks for your efforts
  146. IMI
    Sep 17, 2013
    Very important information that to free. May ALLAH (There is no god but allah) bless you.
  147. Rukhsar Ali
    Sep 08, 2013
    Its my pleasure to be here & i am thankful to you for sharing such information.
    Its too much helpful
  148. quochuy
    Sep 04, 2013
    Thank you very much for your help…
  149. sivapacr
    Aug 22, 2013
    Thanx a lot sir for the great work.
  150. Adem1
    Aug 14, 2013
    Thank you very much for your efforts, it’s really nice job,
  151. trinhminhnhat
    Aug 10, 2013
    thanks so much for ur non-profit work!im grateful for that and dont know how to give a thanks!:(
  152. aakifnouman
    Jul 23, 2013
    You made the life easy thankyou
  153. afk
    Jul 20, 2013
    Suggest any method to design and sizing of control/switch gear panels.
  154. Abdelrazek
    Jul 12, 2013
    Dear Sir;;
    thank you very much for your efforts, it’s really nice job,
    but I want to ask you to put the standards you have used, and pls put the full meanings of the abbreviations you have used.
  155. sat07babu
    Jul 09, 2013
    nice work congrats ….
  156. THIAGO
    Jul 04, 2013
    Awesome!
    Thanks and congratulations for the excelent work!
  157. rahul chauhan
    Jun 29, 2013
  158. lahti
    Jun 27, 2013
    Very nice spreadsheets! Is it possible to make one about 3-phase transformer inrush and aprox. voltage drop caused by inrush?
  159. Mandy
    Jun 27, 2013
    this is wonderful!
  160. mycandy
    Jun 15, 2013
    Many thank to you!
  161. pnp
    Jun 03, 2013
    nothing more to say…….. a big hug for this help. u r doing a great help to students like me….
  162. BAMBAA
    May 31, 2013
    HI GUYS, SOMEBODY HELP ME HOW TO COMPUTE MAIN DISTRIBUTION PANEL LOAD SCHEDULE. I WISH SOMEBODY HAVE A SPREADSHEET / XLS TEMPLATE. =)
  163. Franklyne Dhayalan
    May 31, 2013
    Thanks for doing a lot of work. It is very good inded.
    Could you please clarify if we use chemical earthing ) meaning moisture obsorbing material is filled in around the electrode) will you calculation still be good enough?
  164. lasser56
    May 09, 2013
    hi thanks for all the good tools you guys have come up with. Actually i’m trying to study electrical services design on my own,i got your eplus menuCAD software which i think is a helpful tool. however i still need some step by step guide notes on some basic things i should know. Can you help with any straight to the point books,articles or any literature on electrical services design?
    thank you and i’ll appreciate any help you give
  165. Kevin Felix
    Apr 18, 2013
    Can someone tell me how to download Electrical MS Excel Spreadsheet.
  166. aleskndr
    Apr 05, 2013
    please how can i download
  167. Tadikamallasairam
    Mar 12, 2013
    could you please tell me how to download these spreadsheets
  168. tarekdia
    Dec 23, 2012
    this is a test format for 13.8 kv switchgear
    1. GENERAL DATA AND INFORMATION
    Panel No : Designation No. : A.Q1
    Manufacturer : ABB Rated Voltage : 24 KV
    Type No. : VD4/P 24.25.25 Rated Aux. Voltage : 125 VDC
    Serial No. : 1VC1AL000 Rated Current : 2300 A
    2. MECHANICAL CHECK AND VISUAL INSPECTION
    ITEM DESCRIPTION CHECKED
    1 Inspect for physical damage / defects.
    2 Check nameplate information for correctness
    3 Check tightness of all bolt connections
    (Torque Wrench)
    4 Check racking mechanism for alignment and
    Smoothness of operation
    5 Check quality of paint work
    6 Check proper operation of all mechanical interlocks
    7 Check for correct breaker position indications
    8 Check for correct spring status indication
    9 Check all wiring correctness as per approved drawings
    10 Check that all grounding are securely connected
    3. ELECTRICAL TESTS
    3.1 Function Test.
    1 Local control, alarm and indications
    2 Remote control, alarm and indications
    3 Check correct operation of all auxiliary “a” and “b” switch contacts.
    4 Check breaker operation counter
    5 Check trip free and anti-pumping circuit
    6 Check electrical operation of breaker racking tracks. (interlocks and limit switches).
    3.2 Insulation Resistance Measurement:
    TEST
    VOLTAGE
    CONDITION
    DURATION
    READING (TΩ)
    5KV
    CB CLOSE: R-Y+B+GROUND
    1 MIN
    CB CLOSE: Y-R+B+GROUND
    1 MIN
    CB CLOSE: B-R+Y+GROUND
    1 MIN
    CB OPEN: R1+Y1+B1-R2+Y2+B2+GROUND
    1 MIN
    3.3 Contact Resistance Test: Current injected 100A
    CONDITION
    R-PHASE
    (µΩ)
    Y-PHASE
    (µΩ)
    Y-PHASE
    (µΩ)
    CB CLOSED
    Test Kit : Megger & CPC 100
    3.4 Breaker Timing Set
    TEST
    RΦ (in mSec)
    YΦ (in mSec)
    BΦ (in mSec)
    Closing Operation
    Closing Coil
    Open Operation
    Tripping Coil 1
    Open Operation
    Tripping Coil 2
    Test Kit: EGIL
  169. roel
    Dec 08, 2012
    Thanks to all the contributor and developer of this site/forum…very helpful
  170. ali1980
    Nov 27, 2012
  171. psrpskumar
    Nov 26, 2012
    thankyou very usefull for me
  172. cmurugan-design
    Nov 15, 2012
    Pls post current transformer design xlx
  173. m0Handaznelson
    Nov 01, 2012
    Superb! very useful, i learned a lot…thanks…
  174. mohamed Iqbal
    Oct 31, 2012
    THANS VERY HELP FULL
  175. akira
    Sep 19, 2012
    Sincere thanks and appreciation to this wonderful forum
