Reliability of Substation Configurations
Reliability of Substation Configurations (on photo: The new Great Plains Energy Cole Creek Jct. Substation via David Budka, Flickr)
Introduction to power substation
While one of the strongest points in a power system is the electric substation, it still contains what could be described as weak points or points of failure that would lead to loss of load.
By knowing how to calculate the reliability of different substation configurations, an engineer can use this information to help design a system with the best overall reliability.
But determining the reliability of a substation can also be important for existing installations as it can help locate weak points that may be contributing to overall system unreliability.
This paper will present an overview in determining substation reliability indices and then through the use of an example show how various configurations can be compared.
Sngle bus - Low profile
Sngle bus – Low profile
Before embarking on determining reliability, the purpose of the assessment should be clearly evident as this may affect the choice of which method is used to determine reliability.
A method may look at how substation reliability affects the overall system reliability, how the system reliability affects substation reliability, or substation reliability decoupled from the rest of the power system. Methods may also be better suited to specific types of substations such as transmission and switching, distribution or industrial.
Switching and reconfiguration events typically will use a more complex method of reliability assessment than those used to look at a single substation design.
This paper will concentrate on determining the reliability of a substation not including system wide effects.
Title: Reliability of Substation Configurations – Daniel Nack, Iowa State University, 2005
Format: PDF
Pages: 19
  1. Prof. Nazar M. Karyar
    Oct 05, 2014
    Maintaining and electric motor properly (according to this article’s concept), we are actually saving energy in our industrial world that serve the rapid-growing population of this world.
    best regards, for your professional article being published
    Prof. Nazar Mohd. Karyar – from Afghanistan.
