Home / Download Center / Electrical Engineering Books, Technical Guides and Publications / Power Substation Guides / How to assemble LV electrical switchboard – Technical guide
How to assemble LV electrical switchboard - Technical guide
About this technical guide
This guide presents and illustrates all the best practices to apply when building low-voltage switchboards, in compliance with IEC standards 61439-1 and -2The application of these rules means strict compliance, not only with applicable regulations and standards, but also with manufacturers’ recommendations.
This guide has been updated to take into account recent changes to standards and the latest technological advances in switchboard assembly and installation. It draws on experience acquired by Schneider Electric and its customers over many years.
It is intended for use by panelbuilders in the factory and on-site and also by design engineers to integrate design rules.
It is structured according to the logical procedure for switchboard building from the receipt of components in the workshop to the transport and installation of the complete switchboard on site.
Power busbar
Power distributed in switchboard
Power is distributed in switchboards through the following means:
  • A main busbar that distributes power horizontally between the various switchboard columns. It may be installed on the top, middle or bottom of the switchboard depending on the type of switchboard, customer specifications and/or local practices,
  • Distribution busbars connected to the main busbar. They provide power to outgoing devices.
IEC 61439-1
Power busbar assembly
The following must be taken into account when choosing a power busbar:
  • Environmental characteristics of the switchboard (ambient temperature, IP degree of protection, pollution),
  • Type of switchboard installed regarding to validation test,
  • Characteristics of the client’s power supply: on the top, middle or bottom,
  • The rated current of the short-circuit: Icw.
The installation of a power busbar consists in the following steps:
  • Select the busbar material,
  • Size it (busbar section, number of busbars per phase) and define its position in the switchboard based on the client’s incoming devices,
  • Install it in compliance with the creepage and clearance distances of the standard,
  • Fasten it according to good practice.
Protection of persons
The installation must ensure the protection of persons:
  • Against direct contact by installing the appropriate internal partitions (forms) or by installing live parts out of reach.
  • Against indirect contact by creating an equipotential bonding inside the switchboard (PE/PEN protective conductor and earthing of the grounding electrode conductors).
Protection of persons (direct and indirect contact)
Current transformers
Current transformer
Current transformer
The current of a power busbar is measured using a current transformer (CT) such as a busbar passing current transformerThe main role of the current transformer is to lower the value of the current to be measured to a value that is acceptable for metering devices (usually 1 to 5 A).
Title:How to assemble LV electrical switchboard – Technical guide – Schneider Electric
Pages:292
  1. Francis Belale
    Mar 20, 2015
    Nice to know.ty
