UPS Selection, Installation and Maintenance
UPS Selection, Installation and Maintenance (photo credit: apibattery.com)
Purpose of uninterruptible power supply (UPS)
The purpose of this publication is to provide guidance for facilities engineers in selecting, installing, and maintaining an uninterruptible power supply (UPS) system after the decision has been made to install it.
This technical manual has been prepared to provide generic guidance to agencies responsible for the selection, installation, and maintenance of UPS systems at Command, Control, Communications, Computer, Intelligence, Surveillance, and Reconnaissance (C4ISR) facilities.
Although it is written mainly for C4ISR facilities, which require a higher level of reliability, it could also be utilized as a reference in similar applications.
Scope
The process for identifying the need for an UPS system, selecting, installing, and maintaining the UPS system are covered.
Covered are: theory and principles of static and rotary UPS systems, design and selection of UPS, installation and testing of UPS, maintenance and operation of UPS systems, principles of static and rotary UPS, UPS system rating and sizing selection, operations/maintenance, batteries, troubleshooting, harmonic distortions, grounding, checklists,
and acceptance testing.
Principles and configurations
An UPS system is an alternate or backup source of power with the electric utility company being the primary source. The UPS provides protection of load against line frequency variations, elimination of power line noise and voltage transients, voltage regulation, and uninterruptible power for critical loads during failures of normal utility source.
An UPS can be considered a source of standby power or emergency power depending on the nature of the critical loads.
The amount of power that the UPS must supply also depends on these specific needs. These needs can include emergency lighting for evacuation, emergency perimeter lighting for security, orderly shut down of manufacturing or computer operations, continued operation of life support or critical medical equipment, safe operation of equipment during sags and brownouts, and a combination of the preceding needs.
Title: Technical Manual: UPS Selection, Installation And Maintenance
Format: PDF
Pages: 138
UPS selection, installation and maintenance
6 Comments
  1. Eugenio Roncelli
    Dec 21, 2015
    Very, very old document: nowadays, only IGBT are used in UPSs, with a lot of different (and reduced) problems.
    No mention of “on-line”, “off-line” (known also as parallel/series) functioning.
    Document not useful for modern solutions.
  2. Chandra Mouli
    Oct 24, 2013
    you told about the UPS that’s good but i want to know how to calculate the back up time for ups
    • Mahantesh
      Mar 27, 2015
      As i now i have tell . battery capacity measured by AH
      formula is there IT=AH
      I = AMPS
      T = TIME
      then we have to now what is the load we are using
      exp take 200 AH battery , and load is approximately take 10amp
      then T= AH/I
      T= 200/10
      T=20 time in second like that no battery and increase load.
  3. Anand
    Aug 26, 2013
    Can you explain why sometimes ELR trips when isolation transformer connected on the output side of the UPS. so in this case, if it is put on the input side what is the procedure to be followed.
  4. harsha
    May 23, 2012
    The material Provided is fine. If possible can you please explain the battery , UPS sizing calculations with any practical example which would be really helpful for us.
  5. PRABHAT KUMAR
    Nov 25, 2011
    Really, that’s well..As i pertain to Networking arena, The Topic of UPS somewhat enhanced to gather my information…. Mostly, i have observed that topics are belonged to ..Transformers, power grids and so….. In short i would like to entreat all of our scholars to sprinkle the topic of Networking Tools and Diagnose also……
