Electrical Power Supply And Distribution Book
Electrical power systems //
Electrical power systems can be composed of the following:
  1. Subtransmission lines to main substations;
  2. Distribution lines to distribution substations;
  3. Utilization lines to distribution transformers; and
  4. Generators to provide emergency, stand-by, and/or prime power for mission essential/critical loads.
Generally, for Army base-wide distribution changeouts, the preferred CONUS voltage is 13.2 kV or 13.8 kV three-phase, three-wire, with delta primary and wye secondary transformer connections. When extending existing distribution systems, the preferred distribution voltage is the same as the existing distribution voltage.
Use of 15 kV nominal-class systems is preferable to 5 kV nominal-class systems unless system studies indicate a clear advantage over the 15 kV system. Use of solidly grounded, multiple grounded systems is preferredover single-grounded or ungrounded systems.
For Air Force, the preferred CONUS distribution is 12,470Y/7,200 volt, three-phase, with delta primary and wye secondary transformer connections. Voltages for facilities outside of the United States are specified in AFM 86-3.
Title: UNIFIED FACILITIES CRITERIA (UFC) – Electrical Power Supply And Distribution
Format: PDF
Pages: 125
Electrical power supply and distribution
7 Comments
  1. mohsen
    Jan 24, 2014
    the best
  2. schuccy
    Dec 08, 2011
    I have gotten a great deal of info and i am very grateful for this site,
  3. ramsey
    Jul 11, 2011
    pl send above mentioned book above my E- mail address
      Edvard
      Jul 11, 2011
      Do you have some problems with downloading? As far as I know, download link is working ok.
      • mirfan104
        Sep 02, 2013
        yes.i am struggling to download articles. kindly help me
