Guide to Planning of Electric Power Distribution - by Siemens
Guide to Planning of Electric Power Distribution – by Siemens
Integrated Planning – Cost Reduction
The planning of electric power distribution in buildings and infrastructure facilities is subject to constant transformation. The search for an assignment-compliant, dependable solution should fulfil those usual requirements placed on cost optimisation, efficiency, and time needs. At the same time, technical development innovations and findings from the practical world are constantly seeping into the planning process.
Our books on electric power distribution are intended to support you in your work as a designer and to provide you with a continuously updated and dependable instrument.
The specific requirements of infrastructure facilities of individual industries and building types on electric power distribution is worked on in the application manuals.
Totally Integrated Power – integrated solutions for electrical power distribution
Increasingly greater demands are placed on modern buildings. As early as in the planning stage, demands for a high level of safety, flexibility throughout the entire life cycle, a low level of environmental pollution, the integration of renewable energies and low costs must be taken into account in order to exploit the full potential of economic efficiencies and fulfilling technical demands.
A special challenge is the coordination of the individual installations.
Basically, the main installations are: heating, ventilation, air conditioning and refrigeration, fire protection, protection against intrusion, building control system and electric power distribution. With innovative planning, the requirements are not simply broken down to the individual installations, but have to be coordinated.
Guide Contents //
  1. General Planning Considerations
  2. Basics for Drafting Electrical Power Distribution Systems
  3. Power System Planning Modules
  4. Planning of Medium-Voltage Grids
  5. Quality of Supply
  6. Dimensioning of Power Distribution Systems
  7. Protective Devices for Low-Voltage Distribution
  8. Medium-Voltage Switching Devices and Switchgear
  9. Transformers
  10. Low-Voltage Switchgear and Distribution Systems
  11. Low-voltage Protective and Switching Devices
  12. Starting, Switching, and Protecting Motors
  13. Supply using Converters and Generators
  14. Energy Management
  15. SIMARIS Planning Tools for the Efficient Planning of Power Distribution
  16. Lighting Inside Buildings
  17. Appendix
By the way, the greatest potential for the optimisation of a project is during the planning phase. At this stage, the course is set for additional costs and cost increases which may incur during the erection and subsequent use of the building.
Title: Planning of Electric Power Distribution // Technical Principles – Siemens
Format: PDF
Pages: 372
Planning of Electric Power Distribution // Technical Principles - Siemens
