Home / Download Center / Electrical Engineering Books, Technical Guides and Publications / Electrical Engineering Guides / Lighting And Electrical Systems Design Guide (Elementary School Building Example)
Lighting and electrical systems design guide - An example of elementary school building
Lighting and electrical systems design guide – An example of elementary school building
Design through an integrated approach
The lighting and electrical design of elementary school is devided into following parts:
  • Electrical Design
  • Lighting Design
  • Fire Alarm Design
  • Telecom Design
Distribution of electrical energy
The school’s electrical system will consist of three-phase 480/277V power and three-phase 208/120V power. The incoming utility feed is assumed to be three-phase 4,160 Volt. This incoming feed enters the building from the Park Avenue street side of the building running parallel with the natural gas, water, and telecommunications utilities.
The service terminates in the building’s main electrical room which is centrally located in the basement level. At the unit substation which consists of a main service breaker-disconnect, a 750 kVA delta-wye transformer, secondary breaker, and secondary switchgear distribution section, the main service is stepped down from a three-phase 4,160V delta to a 480/277V wye configuration.
From here the system splits into the building’s three main power branches – life safety, emergency, and normal. The life safety branch will carry all loads deemed necessary for the protection of human life. The emergency branch will carry all loads that are necessary for safe and reliable operation of the school as an emergency natural disaster shelter.
Supplying standby power for the life safety and emergency branches will come from four Capstone 65kW natural gas microturbines, which will be discussed later in this document (Please see the attached electrical riser diagram for a more detailed organization of the electrical system).
Riser diagrams
Riser diagrams
The preliminary sizing for all equipment was based on a tabulation that can be found on page 25 of the supporting documents and also details of this equipment can be seen on pages 29-30.
Equipment Layout
As mentioned before, the unit substation will be located in the building’s main electrical room in the basement level.
Also, this room will house the main distribution panels for each of the three power branches – life safety, emergency, and normal. The automatic transfer switches for the life safety and emergency branches will be located here as well.
Main Electrical Room Layout
Finally, each branch will be provided with a 480/277V lighting panel, transformer, and 208/120V double-tub receptacle panel in the main electrical room.
Title: Lighting And Electrical Systems Guide – ASCE Charles Pankow Foundation Architectural Engineering Student Competition
Format: PDF
Pages: 45
Lighting And Electrical Systems Design Guide - An Example of Elementary School Building
Lighting And Electrical Systems Design Guide – An Example of Elementary School Building
11 Comments
  1. Mohamad
    Jun 23, 2016
    link to download the guide for the school is not working. please advise
  2. URG
    Mar 12, 2016
    Hi … is it possible if we can get separate section for design, maintenance, operations, installation etc in technical articles or sitemap to easily navigate in relevant field. Moreover, is there any chat room or blog etc available to discuss any query ?
  3. Abderramane GHARIANI
    Jul 10, 2015
    thanks for all your contribution, more we share more we grow our skill leveln, I appreciate your just feeling about the problems encountered by engineers, go ahead
  4. Amine
    Jul 09, 2015
    I don’t know when I click the blue button I don’t see the page of donwload I see another page.
      Edvard
      Jul 09, 2015
      Take a look at the bottom, there is a link for download – ‘Right Here’.
  5. Amine
    Jul 09, 2015
    I can not download this guide can someone sent to me at amineln@hotmail.fr
    thank you
  6. Danish Hayat Latifi
    Mar 30, 2015
    Dear Edward
    Could you plz share the cable sizing excel sheet nd load calculation sheet as i want to know — if i am taking 3 runs of cable from one end to other end , then , why do fault level calculation for 1 run – fault current should also be done considering 3 runs …. In load calculation do we have to consider diversity factor for different panels nd then diversity factor for main panel .
    This is how i do …
    Your clarification plzz
  7. Aamir Baig
    Jan 03, 2015
    I am facing difficulty to download this file, can anyone plz send me at aamirbaig_ngnr@hotmail.com
