Understanding Power Factor
As with any equipment, an electrical system handles its job to some degree of efficiency ranging from poor to excellent. The measure of electrical efficiency is known as Power Factor.
The motors and other inductive equipment in a plant require two kinds of electric power. One type is working power, measured by the kilowatt (kW). This is what actually powers the equipment and performs useful work. Secondly, inductive equipment needs magnetizing power to produce the flux necessary for the operation of inductive devices. The unit of measurement of magnetizing or reactive power is the kilovar (kVAR). The working power (kW) and reactive power (kVAR) together make up apparent power which is measured in kilovoltamperes (kVA).
Most AC power systems require both kW (kilowatts) and kVAR (kilovars). Capacitors installed near the loads in a plant are the most economical and efficient way of supplying these kilovars. Low voltage capacitors are traditionally a high reliability maintenance-free device.
On the spot delivery of magnetizing current provided by capacitors means that kilovars do not have to be sent all the way from the utility generator to you. This relieves both you and your utility of the cost of carrying this extra kilovar load. The utility charges you for this reactive power in the form of a direct, or indirect power factor penalty charge.
In addition, you’ll gain system capacity, improve voltage and reduce your power losses.
Title:How Power Factor Corection Works
Pages:16
Hower Power Factor Works
8 Comments
  1. waleed
    Apr 16, 2015
    So Sorry I forgot to thank you for the interesting information
  2. waleed
    Apr 16, 2015
    I think you can provide us with new books of electronics and electricity
  3. Raffy F. Yanuario
    Oct 11, 2014
    very good info…
  4. MODUGULA
    Mar 06, 2013
    it’s fantastic
