Faults on Electrical System
Faults on Electrical System (on photo: Electric Thermography or thermal imaging as one of the safest ways to detect faults not visible to the naked eye)
Transient Instability
In Electrical system there is an interrupted system called Fault, a connection or a situation that causes an unbalance among the three phases. That can be broken down into three groups of balanced vectors. When all the factors have been tentatively selected and balanced, they should be checked by calculations for the limiting the fault condition.
Such calculations can be made by hand but are very laborious if more than two generating stations are involved, and in such cases the use of the a-c calculating board is the only satisfactory means of solution.
Foregoing discussion has treated transient stability when faults occur.
However, a first consideration in system design is the prevention of faults. This includes such factors as clearances, ruggedness of structures, lightning-diverting cables and towers, and guards against birds and animals.
With proper structural designs and fast clearing of ground and phase-to-phase faults, the possibility of three-phase faults on the higher voltage lines can be practically eliminated.
The researcher chooses the topic “Faults on Electrical System” to discuss the types fault systems on how to be cleared out into the system, another form that will satisfy on the electrical system.
Statement of the Problem
In general, transient instability results when the flow of synchronizing power between generating stations during and following a fault is insufficient to overcome the speed changes acquired by the generators during and following the disturbances quickly enough to prevent faults, system design are usually requires that transient stability shall be maintained if the most important interconnecting line of a network shall be tripped out due to one or more of the faults which may be experienced.
Transient stability for three phase faults on the main lines of a transmission system is to be cleared.
The Researcher picks the topic “Faults on Electrical System” to determine the importance of the faults and to eliminate them to the system.
Guide information
Title: Faults on Electrical System – Victor C. Racaza IV
Format: PDF
Pages: 20
  1. Frederic Michel
    May 07, 2014
    i know the system thermique camera
    it is very well for save your equipement
    i recomend if you can control the totality every years for awiod problem fire or destoy electrical connect
    in France we control every year obligatory and we appreciate
  2. saikumar sv
    Nov 03, 2013
    yes.it is very much useful to students .because clear concepts and new technologies are directly available with out many more searches and time saving,also quick referance also possible here. THANKS TO EEP.
