Electrical Engineering Formulas
The theoretical foundation for EE is electromagnetism. The theory of classical electromagnetism is based on Maxwell’s equations, which provide a unified description of the behavior of electric and magnetic fields as well as their interactions with matter.
In practice however, circuit designers normally use simplified equations of electricity and magnetism and theorems that use circuit theory terms, such as Ohm’s law modified for AC circuits, voltage and current Kirchoff’s laws, and power relationships.
Title:Electrical Engineering Formulas – Lazar Rozenblat
Basic Electrical Formulas
  1. R.Prabhakar Rao
    Nov 07, 2015
    We need data of electrical engineering for giving training.
  2. javed Sutar
    Jun 25, 2014
    Why efficiency is considered while calculating current from HP? Efficiency is not considered when KW used.
    • J N Karamchetti
      Feb 15, 2016
      Capacity of motors (HP) is the out put of the motor. So input (kW) to motor is Out put/ Efficiency of Motor. So current (AMP) of motor = KW / Voltage (1 Ph) or kW / ((sqrt3)*Voltage* PF) (3 Ph).
  3. vasanth
    Feb 15, 2014
    its too helpful to me. thanks for your job.
  4. r sarwa
    Oct 20, 2012
    pls, post a guide for electrical unit and their conversion
      There must be conversion included in some of the already available guides, but I’ll try to get something!
  5. reman130488
    Dec 27, 2011
    the document is corrupt. plz check document
  6. samuel
    May 30, 2011
    This will be of a tremendous help to me
      Glad you like it! If you have any suggestion regarding electrical formulas, you can post it here.
