Motor Book - Grundfos
Motor Book – Grundfos
Standards for AC motors
IEC 60034-2 Efficiency standards
Several standards for testing electric machinery exist on a worldwide basis. For induction motors, the three most important ones are IEEE Standard 112, JEC 37 (Japan) and IEC 60034-2. The efficiency value obtained from the different testing standards can differ by several percent.
This seems in contradiction with the theoretical definition of the efficiency:
  • η = power out / power in
  • η = 1 – overall losses / power in
The losses in an induction motor are distributed as follows:
  1. Stator winding loss Pcu1 – approximately 40-45%
  2. Rotor winding loss – Pcu2 – approximately 15%
  3. Friction loss Pfric – approximately 10-15%
  4. Iron loss Pfe – approximately20%
  5. Stray loss Pstray – approximately 10%
Loss distribution in an induction motor
The main difference between the standards is the way in which the fifth loss component stray loss (Pstray), the additional load losses, is treated .
Standards for the testing of motors
The testing of standard motors is described in IEC 60034-2. In the following paragraphs two different methods of testing motors are presented: The direct method and the indirect one .
The difference between these two methods is the way in which the motor efficiency is established.
IEC 60034 covers the so-called industrial motors . Requirements of domestic appliances are listed in IEC 60335, which specifies somewhat different (stricter) requirements of the motors . In addition to the tests of standard motors our laboratory also undertakes to test products integrating motor and pump .
In principle the thermal tests are the same, but the tests are carried out according to other standards . Small circulator pumps are for instance tested according to IEC 60335-2-51.
Title:Motor Book – Grundfos
  1. katakwar
    Aug 20, 2015
    Thank you very much EEP.
  2. Mark E
    Jun 29, 2015
    Thanks for providing an excellent website. I want to download the book on motors titled, “Motor Book – Grundfos” but the link is not working. The link is not a PDF file as it should be. Can you please send me this download in my email or fix the link on the download page. I really appreciate your website. It is an excellent resource, and would be even better if those download links worked as intended.
  3. mohammad mahdi share pasand
    Jun 28, 2015
    Dear authors
    I would like to thank you for this useful portal and its helpful contents. wish you good luck. hope you go on.
  4. Andy Walsh
    Jun 09, 2014
    It may be due to my security settings (I don’t know) but I’m unable to to download most of the material on the site.
  5. tawfik ben mussa
    Jun 09, 2014
    excellent informations , useful for students and professional engineers, i only feel sorry for not having these e books earlier, it could save me a lot of time an efforts. Thanks and keep the good work
    Jun 08, 2014
  7. Ehsan Daryabeigi
    Jun 08, 2014
    Dear Mrs/Mr
    I would like to download a book entitled “Motor Book – Grundfos” from your site. However, it is not possible for me to do that for even others.
