Lessons in Industrial Instrumentation by Tony R. Kuphaldt
Lessons in Industrial Instrumentation by Tony R. Kuphaldt (photo credit: jobmail.co.za)
Automated measurement and control
Instrumentation is the science of automated measurement and control. Applications of this science abound in modern research, industry, and everyday living. From automobile engine control systems to home thermostats to aircraft autopilots to the manufacture of pharmaceutical drugs, automation surrounds us.
This guide explains the fundamental principles of industrial instrumentation.
The first step, naturally, is measurement. If we can’t measure something, it is really pointless to try to control it. This “something” usually takes one of the following forms in industry:
  • Fluid pressure and flow rate
  • The temperature of an object
  • Fluid volume stored in a vessel
  • Chemical concentration
  • Machine position, motion, or acceleration
  • Physical dimension(s) of an object
  • Count (inventory) of objects
  • Electrical voltage, current, or resistance
Once we measure the quantity we are interested in, we usually transmit a signal representing this quantity to an indicating or computing device where either human or automated action then takes place. If the controlling action is automated, the computer sends a signal to a final controlling device which then influences the quantity being measured.
Final control device block diagram
This final control device usually takes one of the following forms:
  • Control valve (for throttling the flow rate of a fluid)
  • Electric motor
  • Electric heater
Both the measurement device and the final control device connect to some physical system which we call the process (shown above as a general block diagram)
Title:Lessons in Industrial Instrumentation // Version 2.13 (development) – Last update August 13, 2015 – Tony R. Kuphaldt
Pages:3209
Download:Right here or here | Get Download Updates | Get Technical articles
  1. Dmitriy
    Jun 11, 2016
    Thank you so much for writing this book! God Bless!!
  2. Kenneth ugorji
    Sep 30, 2015
    Hello, Hw are you doing hop fine, if infact i must tell u this, i love what you are doing, inpacting engineering into a lot of people, all the topics are good. It has help me so much on my job, keep It up. I will like you to talk on DC generator pmg systems
  3. sirelkhatim
    Aug 22, 2015
    This is a very good lesson to me as a mechanical engineer involved in maintenance of mechanical, electrical and instruments hoping you be able to further explain the interface between PLC and instruments.
